James from Tennessee
I am working to design a contraption that can use different size and horsepower rated vertical shaft air cooled engines, from 3 to 27hp. Are holes at the bottom of the engine for the mounting bolts all the same, or do they vary according to the size of the engine? Also, are the dimensions of the output shaft for each engine all the same or do they vary?
Thank you.
Thank you.
