- Sep 24, 2017
- 280
- 6,788
More than enough.
Just barely adequate - for a deuce-and-a-half cargo truck. DAAAANG!So I got a battery from walmart with 650 cranking amps. Is that enough cranking amps?
YESWow ok I will try that. Man i screwed this up. So once i have the gap set your saying I hold the nut and tighten the allen screw to secure that setting?
Have you checked the pressure release nub on the cam I have the same problem on a mower I’m working on for a customerOk I have Cub cadet 1440 with a B&S 294447-0445-01. I needed to change the head gaskets on this mower and reset the valve clearance to spec. Now when I turn the key the motor only turns a quarter turn and stops. If I turn the key again it will still only turn a 1/4 turn and stops. I needed a new battery because the old one under a test load was showing very weak so I got a new battery. The starter seemed weak with the new battery so I tested it and it would only start on occasion. So I replaced the starter. I also have a new solenoid and its still doing it. I thought maybe I set the valve clearance to tight so I loosened them and still the same thing. What am I missing that could cause this
UPDATE! So I took the drive shaft off and no difference, then I took the PTO of and WHAMMMMO she fired right up. I checked the bearing on the PTO and its jammed tight as a drum... won't budge. Thanks to everyone who helped me with this thing.Have you checked the pressure release nub on the cam I have the same problem on a mower I’m working on for a customer
