SeniorCitizen
- Aug 28, 2010
- 142
- 2,285
Chock the front wheels with an immovable object and see if the back wheels will spin at full throttle. On grass first and then on concrete.
Well, my thoughts are on just replacing the motor. I bought this mower used and I think the motor had been replaced with an undersized 18hp by the previous owner. I was told the B/S has a 27hp that will bolt right in with a little wiring differences. I'm not sold on B/S motors--I just have to work on them way too much. Do you have any suggestions as to a motor that would fit my 2005 RAM44? I saw some new Dixons that have Kawasaki engines... any input? Thanks guys and have a great 4th of July holiday!
maaaaate... no way is an 18/27 shift make any difference to your problem.
Even a rooted 18 will drive up to near on full deck speed in grass, then choke
down when the going gets tough.
What you describe in your OP is pretty much my experience with a lower bearing
in the clutch pack 'grabbing'. As mysterious as it was I dissembled the clutch (not easy)
and confirmed that bearing was U/S. From water intrusion by bad design, I would add.
Very disappointing from Borg Warner. Cheap and nasty.
New bearings - and modified the design while I was at it - and away we went.
A clutch pack is a lot cheaper 'experiment' than a motor and a darnsight quicker.
IF you just have to have an engine as a 'play' then make sure you read my recent posts
on my FR541V... Kawasaki is not all it is cracked up to be. TRUST THAT!
.... jes sayin' like.
KK
Did you try and choke it when you engaged the PTO, as I suggested? I was wondering if it worked.
It is looking that way, yes. But before you start jumping all over the shop do a compressionAre you thinking it could be a transmission issue?
test on the engine and check it revs up with no load, take the drive belt off.
KK
