You need a cylinder compression gauge. You can get it in any auto parts store.
Check the deck belt tension. Your unit has manual belt tension adjuster. It isn't a spring-loaded one like you'd normally find on many other mowers...make sure that is not too tight.
I'll see about getting a gauge. I thought about belt tension and will drop the deck and go over everything. I keep hearing this voice telling me its the bearings, its the bearings but that voice isn't always right..... that's why I'm here! lol
