Motor acts like it is either staved for fuel or flooding out.
Tombo1
  • / Motor acts like it is either staved for fuel or flooding out.
XT1 enduro series EFI LT 42, will start and run for just a little while then it acts like it is either staved for fuel or flooding out, it will eventually die.
I have cleaned the carburetor, and injector, and it’s getting good fuel to the carb. Any suggestions?
If you have the MIL light is it flashing a code. If you have push button start does it display an E code. That would help give direction for your issue.
Tombo1
It shows a E4 code
E4 is Oxygen sensor code. Which if it is cutting in and out could have an effect on the fuel ratio.
Tombo1
I will look into that Thanks
