hrdman2luv
- Aug 23, 2014
- 62
- 345
I picked up a little Huskie push mower the other day. Not sure of the model number. But for this, I don't think it's important. When I pulled the dip stick, there was some nasty, hard molasses type stuff on the end of it. So, I pulled the drain plug, and almost nothing that resembled oil came out. I added some oil used oil, that had some gas in it, and let it set for an hour or so. Then drained pulled the drain plug again. Still almost nothing come out, until I stuck the hole with a short nail.
Can someone give me an idea on what to use to loosen this up? Straight gas? Fresh oil changes (a lot of them)
Note: I added some new oil to it, cranked it, and let it run for about 10 minutes. Drained it out. Still lots of that stuff in there.
