I have a MoJack Pro that I've had for 3-4 years. This jack is primarily used at a cemetery to maintain a Hustler X-ONE with a rear discharge deck. I like the Pro as it has a higher capacity and with a winch for lifting, it is quicker than the jackscrew models. Initially it was purchased for use on an older model Hustler ZTR that with a front deck mounted engine was heavier in the front than the X-ONE ZTR. MoJack makes lower priced models with screwjacks, but all are easy to assemble, partially disassemble and store either on the ground or hanging on a wall. In the pics you can see that my shop has a pit, so I am able to get under most machines by turning them sideways across the pit and removing the pit covers.
There are many Chinese produced equipment jacks available in many configurations, none of which I would own. When items are manufactured with the primary idea of being easy to package, put in a container for shipment and with the end user being the least respected in this sequence of events, I'm not interested. I'm not saying that I don't have any Chinese manufactured equipment, but I will say that every single piece has had to be upgraded or modified in some way to make it work as was intended.
Just some thoughts from
Mad Mackie in CT:laughing::biggrin::smile:
