Modifications for a pulling mower
BALMER21
I got a 77 cub cadet hydrostatic 1250. I am fixing it up for a tug-of-war on asphalt. What kind of modifications could I do to the mower to get it to pull harder and better?
bulldogbones
what are the rules LOL. You want as much weight right ahead of the rear wheels and you want to start out as low as possible. Now if you cant add weight you want your hitch height as high as possible. :thumbsup:
Carscw
Go bigger with your engine pulley. Leave the back one like it is.
Lower your tire air down to around 7psi.
Hook your throttle right to the governor so you can open wide open max RPMs.
I hope your not using the mower you cut your grass with.
And as been said already add some weight about mid mower
(( racing is the only sport that you need two balls ))
BALMER21
The rules are:
All parts must be lawn mower parts.
Weight limit is 1000 lbs
Hitch height 16 inches off the ground
Cannot extend the length of the mower other than for the wheelie bar and hitch.
Should I go smaller with the rear tire size? Right now I have 24x12x12 tires and the first pull did not do so well.
The engine is the stock engine so I am pushing max 12 hp.
