Mower deck Model YTA24V48 Rattling noise coming from under mower
bitshift
  • / Model YTA24V48 Rattling noise coming from under mower
Starting at about the 20 second mark. Happens with or without blades engaged.
Again about at the 25 second mark.
Spindle? Sounds like a bearing of some sort has gone out. Ive hit every grease zert I could find, both when I first got the mower and recently.
Still makes this rattling noise. Seems to make it a bit more with the blades engaged.
I recorded it and put it on youtube. See if you can hear. Might help to turn the speakers up a bit.
https://www.youtube.com/watch?v=zW-YPor-Oj4
Remove the deck & drive belts, one at a time see if the rattle vanishes with one of then off the engine pulley.
grab the PTO clutch and twist it back & forth to see if that sounds like what you are hearing.
mr fix it
I have had a couple of these make noise like that and it was one of the drive belt pulley and the arm that holds it just barely hitting the underside of the floor of the mower just in front of the seat, the belt may be stretched and letting it go back that far. Husqvarna had a service bulletin and a small plastic spacer that fixed it or a new drive belt.
