06compound
- May 8, 2018
- 1
- 21
Those pics worked, thank you. I just got off work, so I'm gonna go get those pics
That single black wire is a ground.
OK did some digging, I'm confused about the M terminal, .. & the one next to it with the YELLOW wires, I think you may have those 2 confused ...... you will have to check closely, the YELLOWS should be on the M terminal......check out these pics & DIAGRAM, ... THIS ... SHOULD be the diagram for your mower as I asked before .. do you know how to read the diagram .??? also examine these pics CAREFULLY, ...... NOTE THE LETTERS ON THE BACK OF THE SWITCH !! ARE THEY THE SAME AS YOURS EXACTLY ??? From what I see, the bottom CENTER terminal should be the "L" terminal ..!!! and "M" should be NEXT to the "G" terminal.
IF so .... THEN this is the diagram to use ... it's used on the 40, 42, & 46 inch deck machines ( see bottom of diagram ) KEEP me up dated...........
View attachment 37592..View attachment 37593..View attachment 37594
AM I clear on all this with you ..????
I lied, there are 2 black wires. One is grounded next to the starter solenoid by the steering wheel shaft and the other runs up to the headlights. The gray wire connected to the carb runs into a pigtail with the black wire from the coil.Where is the BLACK wire connected as a ground .... does it go to the coil ..??
Do you have the connector from the key-switch..?? a picture of it ON the switch wwith the wires ( if you have any left) would be VERY VERY helpful, do you have the connector on the carb solenoid..if so .. what color wire is NEXT to the GRAY wire and is it connected anywhere ..??
I'm NOT there .... YOU are my eyes ...... I can only help YOU ... if YOU help ME !!
can you understand the wiring diagram I posted..??
