model 11 bad steering
Nice pictures but unfortunately not the parts that usually cause the no left turn problem. The problem parts will be underneath at the end of the steering shaft.
And it might use be camera angles but those wheels appear to be toed out.
As senior said it is the end of the steering wheel that gives you the grief.
However check the tie rod ends they get floppy with age and that will make them a bit harder to turn because the angles change.
