Mising midel# tag...need help identifying
For Dealers with access to the MTD dealer site, you can put in a model number like you are looking up parts, and then open the attibutes portion normally listed under the illustrated parts list tab, and on most mowers they will give you the engine model info used on that model.
Thought that might be the case.
Being a franchised dealer must have some advantages.
I am in an affiliation to access a lot of parts info but in reallitiy the only eal difference to Joe public is I get to print ot the full page not just the portion on the scene.
Thanks just the same.
I also need the model number/year for this MTD.
MTD Yard Machines
14.5hp Briggs- Model:287707 Type: 0224-01
42" Deck
7 Speed Shift on the Go
Thanks,
