Microsoft stopping support to Windows 10 today
7394
Yep, want everyone to jump on Win 11, & help them sort out all the bugs..
sgkent
dougand3
I switched to Linux years ago. Tried 10 different distros. Top of list = Linux Lite 6.0, Mint 21.3, Xubuntu 24.04. All 3 are Ubuntu based and easy to transition from Windows. So, it really boils down to what "desktop" (GUI) you prefer. I like XFCE of Xubuntu - an official flavor of Ubuntu w/ 3 years of updates (LTS).
sgkent
The only complaint I have with the Linux series is one of my clients uses AutoCad in their business (surveying) and Autodesk does not support it on Linux systems (although they do support it on Apple systems).
Wine and Wine Tricks I think it's called. Probably a few more programs that allow you to run Windoze programs on a Linux box. I've never tried AutoCad on Linux. Probably a Linux version of AutoCad out there???
Always the dual boot way as well. Windoze and Linux.
upupandaway
11 has more back door, three letter entitie spying capability added of course.
Run this. This will use the firewall and block them. You can also add in your routing table to direct the names to dev null. Also in browsing, don't use Chrome or Edge as they may have hidden spyware. Use Mosaic or Brave and get the extensions to block trackers, spyware, etc. Personally, I use ublock to block all utube adds- it works...
(right click CMD to run dos in administrator mode)
Set-NetFirewallProfile -all
netsh advfirewall firewall add rule name="telemetry_vortex.data.microsoft.com" dir=out action=block remoteip=191.232.139.254 enable=yes
netsh advfirewall firewall add rule name="telemetry_telecommand.telemetry.microsoft.com" dir=out action=block remoteip=65.55.252.92 enable=yes
netsh advfirewall firewall add rule name="telemetry_oca.telemetry.microsoft.com" dir=out action=block remoteip=65.55.252.63 enable=yes
netsh advfirewall firewall add rule name="telemetry_sqm.telemetry.microsoft.com" dir=out action=block remoteip=65.55.252.93 enable=yes
netsh advfirewall firewall add rule name="telemetry_watson.telemetry.microsoft.com" dir=out action=block remoteip=65.55.252.43,65.52.108.29 enable=yes
netsh advfirewall firewall add rule name="telemetry_redir.metaservices.microsoft.com" dir=out action=block remoteip=194.44.4.200,194.44.4.208 enable=yes
netsh advfirewall firewall add rule name="telemetry_choice.microsoft.com" dir=out action=block remoteip=157.56.91.77 enable=yes
netsh advfirewall firewall add rule name="telemetry_df.telemetry.microsoft.com" dir=out action=block remoteip=65.52.100.7 enable=yes
netsh advfirewall firewall add rule name="telemetry_reports.wes.df.telemetry.microsoft.com" dir=out action=block remoteip=65.52.100.91 enable=yes
netsh advfirewall firewall add rule name="telemetry_wes.df.telemetry.microsoft.com" dir=out action=block remoteip=65.52.100.93 enable=yes
netsh advfirewall firewall add rule name="telemetry_services.wes.df.telemetry.microsoft.com" dir=out action=block remoteip=65.52.100.92 enable=yes
netsh advfirewall firewall add rule name="telemetry_sqm.df.telemetry.microsoft.com" dir=out action=block remoteip=65.52.100.94 enable=yes
netsh advfirewall firewall add rule name="telemetry_telemetry.microsoft.com" dir=out action=block remoteip=65.52.100.9 enable=yes
netsh advfirewall firewall add rule name="telemetry_watson.ppe.telemetry.microsoft.com" dir=out action=block remoteip=65.52.100.11 enable=yes
netsh advfirewall firewall add rule name="telemetry_telemetry.appex.bing.net" dir=out action=block remoteip=168.63.108.233 enable=yes
netsh advfirewall firewall add rule name="telemetry_telemetry.urs.microsoft.com" dir=out action=block remoteip=157.56.74.250 enable=yes
netsh advfirewall firewall add rule name="telemetry_settings-sandbox.data.microsoft.com" dir=out action=block remoteip=111.221.29.177 enable=yes
netsh advfirewall firewall add rule name="telemetry_vortex-sandbox.data.microsoft.com" dir=out action=block remoteip=64.4.54.32 enable=yes
netsh advfirewall firewall add rule name="telemetry_survey.watson.microsoft.com" dir=out action=block remoteip=207.68.166.254 enable=yes
netsh advfirewall firewall add rule name="telemetry_watson.live.com" dir=out action=block remoteip=207.46.223.94 enable=yes
netsh advfirewall firewall add rule name="telemetry_watson.microsoft.com" dir=out action=block remoteip=65.55.252.71 enable=yes
netsh advfirewall firewall add rule name="telemetry_statsfe2.ws.microsoft.com" dir=out action=block remoteip=64.4.54.22 enable=yes
netsh advfirewall firewall add rule name="telemetry_corpext.msitadfs.glbdns2.microsoft.com" dir=out action=block remoteip=131.107.113.238 enable=yes
netsh advfirewall firewall add rule name="telemetry_compatexchange.cloudapp.net" dir=out action=block remoteip=23.99.10.11 enable=yes
netsh advfirewall firewall add rule name="telemetry_cs1.wpc.v0cdn.net" dir=out action=block remoteip=68.232.34.200 enable=yes
netsh advfirewall firewall add rule name="telemetry_a-0001.a-msedge.net" dir=out action=block remoteip=204.79.197.200 enable=yes
netsh advfirewall firewall add rule name="telemetry_statsfe2.update.microsoft.com.akadns.net" dir=out action=block remoteip=64.4.54.22 enable=yes
netsh advfirewall firewall add rule name="telemetry_sls.update.microsoft.com.akadns.net" dir=out action=block remoteip=157.56.77.139 enable=yes
netsh advfirewall firewall add rule name="telemetry_fe2.update.microsoft.com.akadns.net" dir=out action=block remoteip=134.170.58.121,134.170.58.123,134.170.53.29,66.119.144.190,134.170.58.189,134.170.58.118,134.170.53.30,134.170.51.190 enable=yes
netsh advfirewall firewall add rule name="telemetry_diagnostics.support.microsoft.com" dir=out action=block remoteip=157.56.121.89 enable=yes
netsh advfirewall firewall add rule name="telemetry_corp.sts.microsoft.com" dir=out action=block remoteip=131.107.113.238 enable=yes
netsh advfirewall firewall add rule name="telemetry_statsfe1.ws.microsoft.com" dir=out action=block remoteip=134.170.115.60 enable=yes
netsh advfirewall firewall add rule name="telemetry_pre.footprintpredict.com" dir=out action=block remoteip=204.79.197.200 enable=yes
netsh advfirewall firewall add rule name="telemetry_i1.services.social.microsoft.com" dir=out action=block remoteip=104.82.22.249 enable=yes
netsh advfirewall firewall add rule name="telemetry_feedback.windows.com" dir=out action=block remoteip=134.170.185.70 enable=yes
netsh advfirewall firewall add rule name="telemetry_feedback.microsoft-hohm.com" dir=out action=block remoteip=64.4.6.100,65.55.39.10 enable=yes
netsh advfirewall firewall add rule name="telemetry_feedback.search.microsoft.com" dir=out action=block remoteip=157.55.129.21 enable=yes
netsh advfirewall firewall add rule name="telemetry_rad.msn.com" dir=out action=block remoteip=207.46.194.25 enable=yes
netsh advfirewall firewall add rule name="telemetry_preview.msn.com" dir=out action=block remoteip=23.102.21.4 enable=yes
netsh advfirewall firewall add rule name="telemetry_dart.l.doubleclick.net" dir=out action=block remoteip=173.194.113.220,173.194.113.219,216.58.209.166 enable=yes
netsh advfirewall firewall add rule name="telemetry_ads.msn.com" dir=out action=block remoteip=157.56.91.82,157.56.23.91,104.82.14.146,207.123.56.252,185.13.160.61,8.254.209.254 enable=yes
netsh advfirewall firewall add rule name="telemetry_a.ads1.msn.com" dir=out action=block remoteip=198.78.208.254,185.13.160.61 enable=yes
netsh advfirewall firewall add rule name="telemetry_global.msads.net.c.footprint.net" dir=out action=block remoteip=185.13.160.61,8.254.209.254,207.123.56.252 enable=yes
netsh advfirewall firewall add rule name="telemetry_az361816.vo.msecnd.net" dir=out action=block remoteip=68.232.34.200 enable=yes
netsh advfirewall firewall add rule name="telemetry_oca.telemetry.microsoft.com.nsatc.net" dir=out action=block remoteip=65.55.252.63 enable=yes
netsh advfirewall firewall add rule name="telemetry_ssw.live.com" dir=out action=block remoteip=207.46.101.29 enable=yes
netsh advfirewall firewall add rule name="telemetry_msnbot-65-55-108-23.search.msn.com" dir=out action=block remoteip=65.55.108.23 enable=yes
netsh advfirewall firewall add rule name="telemetry_a23-218-212-69.deploy.static.akamaitechnologies.com" dir=out action=block remoteip=23.218.212.69 enable=yes
What the heck. Must be page one of all the back door tricks LOL. Wow.
Where did you get this upandup?
Looks like something I need to load into my PFSense box.
dad7432
Windoz 11 won't work on my 7 year old Toshiba PC, which came with Win 8hate, which I manually updated to Windozed 10. Remember how much everyone hated 8? So I got 7 years of support out of a $700.00 machine.
In 2020 My wife gave me a hardened water resistant Asus Chromebook, to use for working outside... in the shop, on the boats, and just for fun. Google claims it will support it until June 2029. It works great. I use it far more often that the more expensive, larger Toshiba. It cost $500.00. When it was partially crushed Asus mail order repaired it for $120. It runs everything I use on the PC, including MS Office and apps work just fine.
7 years of support for a $700 MS Windows Toshiba PC.
9 years from a $500 Chrome computer.
Can you guess which company is going to get my money next time?
upupandaway
Just search for "block spyware" and people point out this. I collected these from several docs online. Look up the command, each line is adding a block entry in the firewall. If it was opening ports, then I would not run it.
It's the world of cmd from the old windows. You can do the same thing manually in the Firewall settings.
Good ol' when u have alot of work to do, script\program it.
