Export thread
McCullugh titan57
#1
Parkmower
Parkmower
I replaced all the gas and oil lines including the pick up lines in the tanks. Cleaned carb. Checked muffler screen. Good compression. Has spark.
It ran great the first day, started easy. Now it starts hard and doesn't want stay running. I ve had the whole apart again. I've tried the hi-lo Adjustments from half turn to three turns out. Tried different spark plug. It has low hours and is in good shape.
Its a chain saw.
Any ideas???
#2
K
KennyV
Could be too rich or too lean...
Easiest to check for too lean, try squirting fuel directly into carb... :smile:KennyV
#3
W
wardsmower
Make sure all the cylinder bolts are tight. They do tend to back out slightly.
#4
Two-Stroke
Two-Stroke
Try checking all bolts, seals, etc that could affect crankcase pressure. Don't forget that a two-cycle engine relies on crankcase pressure to push the fuel-air mixture into the combustion chamber.
Does this engine have a fuel filter? If so, check it. If not, make sure that the entire fuel system is clean -- including all the tiny passages in the carb.
#5
reynoldston
reynoldston
I know you said that you replaced the gas lines, but recheck them because it doesn't take much to draw air into then and it wouldn't run good sucking air. This includes inside the gas tank.
#6
Joe79
Joe79
Stupid question, but did you run it without mix? Check the valves. They could have come loose.
#7
Parkmower
Parkmower
No it's never been run without mixed gas.
#8
Two-Stroke
Two-Stroke
This is a two-cycle engine -- no valves unless you count the reeds. :wink:
