I got this from a friend, it is in excellent shape and hardly used. I have rebuilt carbs many times on trimmers, blowers and saws and have never had this problem. I rebuilt carb with new gaskets, replaced gas lines. Reset the needle valves 1 1/2 turns. Fresh gas, and tried starting. It will fire but will not run, take out the plug and it is wet. Couple times when it would almost start it would smoke. Cleaned off plug and same thing again. I have not changed the plug, I have not had them go bad very often. Any suggestions. Tired of pulling on this thing. Thanks
