Main drive belt Murray 8 30
The Murray belt you gave me 37 X 110 has an English Size of 1/2" by 43 7/8" If my conversion is correct that would be 17.7 cm X 1114.425 cm. I hope this helps you.
Mac 624
some numbers, not sure if they will help, by finding the size:
Modelnr.: 3 - 30708 X 65 0236 (O236?)
Didn't my last post help? Rivets
Mac 624
Iエm a bit confused about the 17,7 cm which is 8" but also 17,7 mm is too large in my opinion.
I have found some Infos: 1/2 " x 40,5" ? Which is 12,7 x 1029 (mm) so a Belt of size 13 x 1030 would be available here without any probs.
I think I found our problem. I used 25.4 cm = 1 in, when I should have used 2.54 cm.
With that mistake solved a 1/2" X 43 7/8" belt would equal 1.27 cm X 111.44 cm. Do you have any belt sizes close to that? Sorry about my mistake and bad information.
Let me know when you get a belt and if it solves the problems.
