I replaced the fan and have used the tractor for about 3 hours with no problems. I think the fluid was overheating and coming out the top of the tank, it has stopped doing that. I found part of one blade when I took the body off, I wonder how they all broke off.
The reservoir is not supposed to be full to the top cold.
When the fluid gets hot the level will raise/expand some from normal operation.
The LX188 does not have a drain plug at all and JD does not intend for a homeowner to change the fluid.
I have changed mine, but I had to remove the transaxle and turn the thing upside down.
It takes forever for the cold oil to drain out.
If you ever try it, get the oil as hot as possible before you start the project.
Maybe you had a tad too much oil in there plus the fan issue...
