LTX cub cadet 1046 460 hours
snorky1961
Everything is working as it should, Except today it started to go real slow in revers and will not back up a hill at all does great forward
JonnyBlaze
Worn drive belt? Needs trans fluid change? Trans going out?
snorky1961
belts good ,, I was looking for trans fluid checked utube I have no manual. As far as trans going out no way to check hope not
Check the linkages at the box.
Good chance the lever has debris around it preventing it from moving all the way.
Unless you mow in reverse all the time , reverse generally never wears out
snorky1961
Guess I should have added it will work great for about 2 hours after than reverse is real weak. I did check trans fluid and belt again. Belt looks good unless it is stretching when it warms up.
Scrubcadet10
Moderator
Staff member
might be the belt. My 1040 does that when the drive belt gets wore.
