snorky1961
Everything is working as it should, Except today it started to go real slow in revers and will not back up a hill at all does great forward
Worn drive belt? Needs trans fluid change? Trans going out?Everything is working as it should, Except today it started to go real slow in revers and will not back up a hill at all does great forward
belts good ,, I was looking for trans fluid checked utube I have no manual. As far as trans going out no way to check hope notWorn drive belt? Needs trans fluid change? Trans going out?
Check the linkages at the box.
Good chance the lever has debris around it preventing it from moving all the way.
Unless you mow in reverse all the time , reverse generally never wears out
