skinnyoldguy
- Oct 25, 2011
- 1
- 3
My Cub Cadet LTX 1040 will not start because of the brake interlock (brake light comes on when I turn key to start). The brake appears to be working as I can not push it with the brake depressed. Also the parking brake lock is not working.
It is inconveniently stuck at the bottom of a long grade and I need to get it up to my driveway to have it repaired. Is there a way I can temporarily defeat the brake safety switch in order to get it out of the yard and up the hill? I would appreciate any help. I do not have a service manual so I would need to know where the switch is located, what to do, etc.
