The thing is, like I said once the starter does kick in it cranks pretty robustly.....
So no voltage at started when clicking, must be the solenoid clicking if that's what is clicking cause it's not the starter making the noise. Should have checked this before starter purchase. Change Solenoid ?
Plenty of battery power. Turning key, seem to hear starter fire but doesn't turn engine. I just keep on turning the key off and on until it cranks it over then starts easily. Is this a starter perhaps something else ?
Did you ever find out the problem. if not you need to check the valve adjustment. If valves are not adjusted properly this will cause hard starting as the engine is hard to turn. Try rotating engine by hand and see how hard it is to turn, if very hard adjust valves. I had this happen several times.
