slimshady69
- Jun 19, 2024
- 1
- 10
I shut my mower off went to restart it now it won't turn over at all. Battery is fine, I have power to the starter. I think it might be the ignition switch but not sure
Huh whatSafety's ?
Safety's ?
Brake pedal depressed and the pto turned off. And in some cases being on the seat or some mowers require the transmission to be in neutral if a gear drive.Huh what
Yeah I know all that still won't turn overBrake pedal depressed and the pto turned off. And in some cases being on the seat or some mowers require the transmission to be in neutral if a gear drive.
If the anti-after fire solenoid on the carburetor does not click when the ignition is turned on, check the fuse; unless, someone has remov
