johnfromwv
- Jun 2, 2022
- 1
- 1
I have an older LT1045. Just replaced the deck belt. After engaging the PTO, the deck spins fine. After engaging the drive, I can mow and it seems normal for the first 10 feet of mowing, but then the deck (not the drive) seems to slow. The longer I mow, the slower I must go to keep the RPMs up on the mowing deck. It seems like the PTO is weakening and needs replaced. If this is true, what's the procedure for the replacement of the PTO, the parts diagram appears to be rather cut and dry, but like everything else, can be deceiving. My question is, does my assessment of the PTO seem correct or am I missing another element that could be causing the rotation of the blades to slow? Engine runs fine, drive runs fine. It's only the deck that slows down, and with the new belt installed, I can't see anything else that could be causing the slowdown.
