LT 2000 WONT START
dukesoz
Hi all, I charged the battery, tried starting hooking charger to disconnected leads, but nothing happens.
It turned slowly b4 I charged battery, but now not a sound.
Can't find the fuse, I need help please.
dukesoz.
If it turned over before you changed the battery and now with a new battery it doesn't I would say bad connection. Clean and tighten all your battery cable connections. I read it wrong charged not changed sorry
Ok before you charged the battery and it was turning over. I am still going to say check your battery cable connections.
The battery could have a dead cell that is keeping it from taking charge. It happens alot with power equipment batteries they arent made like they use to be.
follow your wires down to starter silnoid should b a 30 amp fuse there off the silnoid running to the motor aslo make shure all your saftey switches are close
