Carl Spackler
Hello all, I'm hoping I can get some assistance. The tractor this year started blowing white smoke out the muffler. I've been keeping an eye on the oil level and add it halfway through cutting my 2 acres. Then the last time I cut, the engine was backfiring towards the end of my cutting. I've done a lot of searching online and concluded that the ethanol mixed gas I get might be the problem. I drained and cleaned the gas tank, changed the fuel filter, disassembled and cleaned the carburetor and changed the oil. I filled the tank with 100% gasoline and it ran awesome...until it got hot. It did seem to be blowing white smoke even when cold, but not as bad. It backfires and sputters now when it's hot, especially when I engage the blades. I attached a video of it running, hopefully that will help. I appreciate any suggestions. Tractor M/N: 247.288852. Briggs & Stratton engine #: 331877. In the video, the throttle is full the entire time until the end when I shut it down, at the 50 second mark, I slowly engage the blades. Video: https://youtu.be/jF8iYmYa20U
