Hitechluddite
I installed a new fuel pump and this helped the problem, the fuel filter always remains at least half full even uphill with a near empty tank but intermittently it still runs rough and has a significant loss of power. I pulled the air cleaner and the air cleaner housing plate looking for some carb adjustments but didn't see much, the air filter looks clean and all hoses are attached. The plug on the left cylinder as your sitting on the mower is very lean, almost pure white. I googled a valve adjustment procedure but haven't found one yet, I'll try to D/L a manual tonite but would appreciate any tips on what to look at to resolve this.
