I have a 4yr old INTEK that is slowing loosing power. (Engine Model #33R877/0008-G1)New camshaft - 10/27/23 which fixed the broken compression relief. Seemed to run great after I put it back together.
After mowing six times this year I have low power and it is getting worse.
What I have done so far that has not helped at all:
Tune up 6/01/24 - Air filter, fuel filter, spark plug
Checked flywheel KEY - it was fine
Checked valve adjustment - it was fine
6/7/24 - Replaced carburetor and it runs slightly worse...won't idle all the way down
Always kept good clean oil in it. Because it lugs down more when mowing I removed the deck belt and spun all the spindles and pulleys which were fine.
Questions:
Could the compression relief be stuck giving me low compression (hard to check and never heard of that happening)
I see some INTEK engines have head gasket problems - I see no sign of that, no oil leaks, smoke, or odd sounds.
I have mowed 1/2 acre of level lawn six times and it seems like I have about half the HP I should have.
Thanks for any ideas or things to check.
