I have an Exmark zero-turn with Kawasaki FX801V engine. Brought it in the garage last fall, all was running perfectly. This winter I changed the oil and filter, fuel filter and the rocker cover gaskets because they were leaking a bit. While I had those off I figured I would check/set the valve clearance.
Went to mow this afternoon, started right up and let warm for a couple minutes before I started.
Wheeled over to the yard, half throttle, turned on PTO to start blades, full throttle. Seemed OK for a few seconds then lost power when I started moving. It just is not making full power/RPM’s with mower engaged.
What’s everyones first thought?
