davbell22602
- Nov 27, 2011
- 152
- 1,324
Briggs
120602
0164-E1
020507 FA
New carb Briggs part number 790120. Changed oil, new mower blade, new air filter, new spark plug(Torch), and new engine stop cable. Checked flywheel key and its was good.
Engine rpm's on top speed arent all there unless its Briggs low noise engine. Same type of thats on JD walk behind and everything is same between the 2 engines. Seems hard to start when warm/hot. Started right up when cold start.
Any ideas? Are the valves adjustable on this engine?
120602
0164-E1
020507 FA
