Low Noise Engine or Lacking RPM's?
davbell22602
Briggs
120602
0164-E1
020507 FA
New carb Briggs part number 790120. Changed oil, new mower blade, new air filter, new spark plug(Torch), and new engine stop cable. Checked flywheel key and its was good.
Engine rpm's on top speed arent all there unless its Briggs low noise engine. Same type of thats on JD walk behind and everything is same between the 2 engines. Seems hard to start when warm/hot. Started right up when cold start.
Any ideas? Are the valves adjustable on this engine?
the only way to know for sure if you have low rpm's is your going to need a tach.
davbell22602
OK, But I can tell by the sound that its not very loud and self propelled is slow also.
exotion
Check throttle cable if you have one. Make sure it opens the butterfly all the way.
Check auto choke make sure it has full range of movement.
While running play with the butterflys on the carb see if they are open.
Next check govenor ARM see if it needs adjusting. When hot it should open the carb up all the way.
pugaltitude
Couple of things to try for hard hot start.
The intek has to have spark plug set at 0.020".
The black spacer between the carb and head can distort when engine warmed up allowing more air in than fuel.
Has the safety cut off switch sufficient clearance between the lever when cable operated?
its an ohv engine so rocker cover off.
I think clearances are 0.04"-0.06".
davbell22602
I cleaned the black spacer when the carb was replaced with new gaskets. I manually move the governor to rev the engine rpms up but when the engine rpm's came down I kept hearing a pop sound.
exotion
Popping screams valve adjustment to me
davbell22602
Intake is .003-.005 and exhaust .005-.007 for valve clearance. Air gap .010-.014. Per Briggs manual.
