Low compression
Rturner
Need intake&exhaust valve clearances for Briggs model number 402707
Tinkerer200
I can send you a Service Manual for your engine IF you like, address below, put in proper format and remind me model number and what you want.
Walt Conner
wconner5 at frontier dot com
The Specialist
Intake valve is .006 and the exhaust is .009 of an inch. You should remove the valves and clean them up!! You will have to do this in order to set the gap anyway!!
