My 1996 WheelHorse (260H?) worked great for 20 years when plowing my driveway. Two years ago, the steering "quit" while snowplowing. That is, I could turn the steering wheel 360 degrees and nothing happened to the front wheels. I took it to my repair shop and they replaced the upper and lower steering plates. All worked well with the tractor (did not need to do any snowplowing). On the first snow storm, I plowed half of the driveway when lost steering again; the teeth were not meshing. Back to the repair shop where they reset the plates to mesh the teeth. Again, worked great until needed to snow plow this past Friday...lost steering AGAIN. Is there some reason that pushing snow causes the teeth not to mesh but using the tractor prior to snowplowing works great. Snowplowing was no problem for the first 24 years of ownership but certainly is now. Any suggestions?? Thanks.
