Looking for briggs and stratton parts but i can't find them
jawehner1419@gmail.com
  • / Looking for briggs and stratton parts but i can't find them
i have an older(not sure how old) briggs and stratton. It is on a go kart my uncle built and it has seen better days. before i go ripping it apart i was wondering where i could get parts(online or a store?). It is a 3.5 horse. 148cc
numbers: 92502 3161 01 8708105
I have googled the number in but i can only get the 92502 31 then nothing else is the same. im pretty sure the 61 and the 01 should be the same too? I am looking for piston rings, top end gaskets, carb kit, bearings and some other misc parts. So if anybody can point me in the right direction to find these parts(or interchangable parts) that would be very helpful. Thank you very much!
From the briggs web site support section download the original parts book.
Then use those numbers at any of the parts suppliers listed on this forum ( under the links section ).
The numbers ou type in will most likely all be obsolete but usually they will update to the new ones.
primerbulb120
You can't find parts because you need a number that isn't on the engine. Put a zero in front of the model number, which makes it 092502-3161-01. Now try looking it up and see what you can find.
If you will post pictures of the parts you need, I will try to find aftermarket parts that aren't as expensive.
