Man, that method has to be the cheapest way to add weight to the wheels I know of. Good point about the bearings !! How long did it take you to drill each hole thru 3 inches of steel....and how many drill bits did you go thru in the process?
I actually made 4 of them so I had to drill 16 1/2" holes.
I did it with one bit no problem just took awhile.
I put a set on one tractor and the other set on another tractor but this was years ago I have had these weights on 3 different tractors down thorough the years.
At one point I had all 400 lbs on one tractor I took it to a garden tractor pull. I have a trophy that says Wabash county champion tractor puller.:biggrin:
I got the pieces from a guy that worked at the machine shop, they were worth more for scrap iron than what I paid for them.
Currently I have them on my 430 JD Diesel with tire chains and bar tires.
I have a heated cab and a snow blower on it.
The reason I have so many is I'm very old and have had 2 failed back surgeries and I can not be removing a blower and putting on a mower deck I can just barley walk.
We all have different needs and sometimes when we give others advice we assume they are in good shape but that may not always be the case.
It is very hard for me to get on and off of my tractor. It won't be many more years until I will have to get someone else to do it for me.
