Export thread
lights on an Exmark
#1
cooksqualitylawncare
I just bought a brand new emark and I would like to put a set if lights somewhere on them. Sometimes it gets dark on me and I need a lil light. But my question is where do i hook into them at on all the wires or am I even able to?
#2
K
KennyV
You need to determine how many amps you have available from your charging system... then do not put more light load than you have amps available.
Run a fused wire from the positive battery cable on the starter solenoid to a switch for your lights... continue from your new switch to the lights....
Should work great... and the in line fuse will protect your wiring... :smile:KennyV
#3
What if I don't have an electric start. Mine is a pull start
#4
reynoldston
reynoldston
Install a small motorcycle battery and keep it charged with a trickle charger when not useing the mower.
