JamesD
- Apr 16, 2017
- 16
The mower is a 42 inch poulan pro automatic with a briggs and stratton 17hp intek motor.
Mower PN: pr17h42sta
Mower was running fine last time I cut the grass.
After sitting about a week, I found that grass had built up under the mower deck so rather than removing the deck to clean it I just lifted the front end of the mower until the wheels were about shoulder height. I braced it there with a board and scraped the deck to remove the large chunks of grass. I then spayed it down with a jet nozzle on my garden hose to get some of the dirt off too. Finally I blasted it with compressed air and changed the blades out. It was probably raised up like that for about an hour. After lowering the front end back down the mower refused to start.
It turns over no problem but no ignition. I changed the gas out for fresh gas. I checked the fuel filter and fuel bowl. I tried spraying brake cleaner in through the air vent and then sparkplug hole but no sound of combustion. Cleaned out the carburetor which was in good shape anyway. Replaced the spark plug which didn't look too bad. Checked my wiring connections to be sure power was getting to the plug, it is. Drained and changed the oil.. None of this resulted in the lawn mower firing up. It just cranks round and round as if gas wasn't flowing but it is.
Any help on this will be appreciated.
