Lesco Ignorant
Mowerdawg
HELP! Gotta customer with a Lesco " ztr with the extra two wheels in the rear. Kohler CH26-S. He just purchased and I'm restoring. Can't seem to find any info on this unit. Need a wiring diagram, but factory specs would be really helpful. Anyone know where or does anyone have one to share?
Any helps is appreciated.
:frown:
KennyV
Lesco, Isn't that a John Deere stand on mower line??
Check at your local JD dealer.... :smile:KennyV
Ric
You mite want to contact Cub Cadet, I think Cub Cadet Commercial/MTD are or were making all the Lesco mowers for quite some time. You are probably looking at a Cub Commercial machine in Lesco green paint. I believe Lesco has been bought out by John Deere Landscapes but they no longer sell mowers or do any repairs, so parts availability and service could be an issue.
reynoldston
I know it sure is nice to have a wiring diagram and all the specs and sure make life easier when working on something you are unfamiliar with. Me having a small part time shop I run into this all the time. As far as wiring the engine maybe Kholer service manual which Kohler is very good about putting on line. It really doesn't look like the chassis would have a lot in wiring so just maybe you could wing it from there. As for specs the same deal. I know as for my self when I don't have any information I will just use a generic number and as a rule I get by with it but not always. I hate doing it but some times I have had to go to a dealer service department and ask and as a rule they will help me out.
AdosJones
Howdy, if you are still looking for information on this one I have a PDF of the parts catalog and operator / service manual. There is a wiring diagram in the back.
Send me a PM if you need.
Cheers.
joe740zx
Cheers.
i would like to get that pdf file. thanks joe
