Alex Ethridge
- May 25, 2019
- Threads
- 18
- 77
Near-new Husqvarna RZ3016, Product Number 966612301 used about twenty minutes and then parked for three months in dry carport. Today, the left control arm will not move forward or back. Right control arm works fine but since left control arm seems locked in neutral position, the mower will move only in a circle. Hydraulic pump bypass linkage is disengaged on both sides. In case it matters both left and right rear wheels will roll freely when hydraulic pump bypass linkage is engaged.
966612301 Manual
966612301 Manual
