JESUS freak
- May 9, 2020
- 13
Problem is still present. Any suggestions? New blades (Oregon). ThanksNew blades installed and looks like the problem is cured.
Tire air pressure should be spot on according to your manual specs. Front tires might be low allowing the sidewall to dive in and cut low on turns. Check your air pressure monthly.Problem is still present. Any suggestions? New blades (Oregon). Thanks
This is sort of normal and is a function of the way the blades overlap
Triple check that the front blade is the correct length.
Try turning different curves.
You will see that a specific turn will leave a mowhawk
Happens more or less on every deck that does not have timed overlapping blades
If I repeat this often enough perhaps it will sink in
One blade is foreward of the other so they only overlap when traveling in a strait line
Put two coins on a sheet of paper with some flour on it represent your blades & lawn
Put your fingers on the coins then swing them left & right
You will see one way the overlap increases and the width of cut decreases and the other way the width stays the same but there is a big section that is not cut
The mount this happens will depend upon the mowing speed , they mowing height, the type of blades, the type of grass, the height of the grass.
Has this happened since new? Do you notice this only at certainly cutting heights? If the problem has always been present then it is the result of bad design. If not, then something has gone wrong in/under the deck. As for cutting height, there is a time when the blades may not be processing the clippings fast/efficient enough which is then also affected by turning. I am not familiar with the 48" deck but if I do recall the GSX had many deck options 42-54" and in stamped and fabricated variations. I personally had a mower with the 50" stamped deck and it cut beautifully without trails. Might I suggest reaching out to Cub Cadet customer service or your local dealer as this machine is a dealer only model; they may have some insight into your problem. Generally I would think that the blade overlap in any deck design would account for turning unless there are other variables at play that are not deck related, such as grade, mowing speed, grass length, cut height, blade sharpness, blade tip speed and the list goes on. I don't have an answer but maybe just taking the deck off, flipping it over and rotating the blades by hand to see where they "meet" at the overlap may tell you wherever or not the deck is okay?I have a 2015 XT3 GSX. It leaves a small streak of uncut grass only when i turn right or left. The blades LOOK good. Any suggestions?
Thanks...looks like that is my next option...talk to a local dealer or customer service. I have had the deck off and all LOOKED ok. Thanks fo the reply !Has this happened since new? Do you notice this only at certainly cutting heights? If the problem has always been present then it is the result of bad design. If not, then something has gone wrong in/under the deck. As for cutting height, there is a time when the blades may not be processing the clippings fast/efficient enough which is then also affected by turning. I am not familiar with the 48" deck but if I do recall the GSX had many deck options 42-54" and in stamped and fabricated variations. I personally had a mower with the 50" stamped deck and it cut beautifully without trails. Might I suggest reaching out to Cub Cadet customer service or your local dealer as this machine is a dealer only model; they may have some insight into your problem. Generally I would think that the blade overlap in any deck design would account for turning unless there are other variables at play that are not deck related, such as grade, mowing speed, grass length, cut height, blade sharpness, blade tip speed and the list goes on. I don't have an answer but maybe just taking the deck off, flipping it over and rotating the blades by hand to see where they "meet" at the overlap may tell you wherever or not the deck is okay?
Good luck!
It's only on turns...right or left. The mower was purchased used a year ago. Its a XT3 GSX with a 48 inchfabricated deck. I have used it all season and only noticed it as of lately as the grass has really thick. Earlier i didn't notice it.Pros, at least in my area, mow straight lines on our zero turn mowers, which can be done on a lawn tractor too so you can avoid funky cut quality on turns.
If I get a "mohawk" mowing straight its always between the middle and right blade when mowing heavy growth due to overloading the deck or in line with the left front caster from it laying the grass down. The remedy is a quick second cut. It's almost impossible to get a crisp-looking cut in our cool season grasses on lush lawns cut weekly unless you're running a vacuum bagger.
