JESUS freak
- May 9, 2020
- 4
- 13
I have a 2015 XT3 GSX. It leaves a small streak of uncut grass only when i turn right or left. The blades LOOK good. Any suggestions?
im guessing you have just enough of the edge of the blades are worn down and rounded off so its too short to overlap cut when you turnI have a 2015 XT3 GSX. It leaves a small streak of uncut grass only when i turn right or left. The blades LOOK good. Any suggestions?
Just one side of the deck being 1/8" higher, will not be the cause of leaving a streak of grass......it's something else!I checked the deck level and one side was 1/8 inch higher . This has taken 80-90 percent of it out. The blades look good. I have not measured them for length. This is a 48 inch fabricated deck with 3 blades.
Run Oregon blades.
