Hi All,
Last week my 10515 started running rough and stalling.
I replaced the coil, new plug, air filter, cleaned the exhaust ports
and cleaned the carb.
This only made things worse, the mower now hesitates, pops and
smokes out of the exhaust. Almost sounds like the timing is off.
The nut on the flywheel is tight so I doubt the flywheel has shifted position.
I'm a bit stumped at the point so would appreciate some pointers
of where to turn next.
Thanks!
John
Thanks!
John
