Lawnmower Lift Table?
Anybody have a nice set of plans for a mower lift table?
I do. It's a four post lift. Probably going to use 4X4 posts, with 1/4" cables connected to a 2,500lb winch, connected to a battery. It's just in the planning stage now. Not sure if I wanna use wood or steel. But, the idea is there.
Just roll right up on it. Push a button and it goes up as high as I need it too. Easy access to everything around a rider.
I use an old pallet yard crane,
There are lots of them out there ,
Being a 2 ton lift , great for getting under the work van as well.
I tried a lot of different things, but the lift works best as to do anything under the mower , apart from attend to the blades you have to remove the deck first.
Whooooooooooooooo Pig, Soooooooooooouuuuuuuuuuuiiiiiiiiiiiiieeeeeeeeeeeeeeeeeeeeeeeeeee!
