T TomCornwell Forum Newbie Joined May 17, 2013 Messages 2 May 17, 2013 #1 I replaced the belt, adjusted the engagement cable and still does not work. Any suggestions on what to check next?
Fireman 123 Well-Known Member Joined May 14, 2011 Messages 358 May 18, 2013 #2 Pull the rear wheels and inspect the gearing.
turfboy1997 Well-Known Member Joined Apr 24, 2012 Messages 164 May 19, 2013 #4 Your belt pulley on the crankshaft has a allen head set screw that holds it on. if it shears that set screw it will not spin with the crankshaft when the self propelled is engaged. the part number is 610345.
