Hello. I'm fixing up this old mower. It has the D600 motor. I need to get an on/off switch, primer bulb (the current one is as hard as a rock), replace the hand grip, and fix the gas leak coming from the gas shut off valve. I have some questions:
1. Will the LB 89817 grass bag kit fit my model?
2. How do you get the old gas shut-off valve off without breaking the tank assembly?
3. I see some replacement white hand grips on ebay but I would actually like a green one so it wont show the dirt as easy. Is there one out there?
