Rudedog
- May 6, 2012
- 7
- 63
93 octane is fine .i have always used it and my mower repair shop suggests it. these are not high compression engines so i doubt if it affects performance.
Thanks Reed!
I've switched 90% of my customers to Opti 2 two cycle oil for all my engines except chain saws. Even the old LB's and two jakes. Have not had any problem, plus the same gas can be used in 24/1, 32/1, 40/1, and 50/1 engines. A lot less gas cans in the shop. Chain saw get stiehl synthetic or moto mix if they get stored for a long time.
Cautioned by whom?I have been cautioned NOT to use a 2 cycle oil that has been formulated for outboard engine use as they lack the viscosity to protect our air cooled lawn mower engines.
I do not think that castor oil is miscible in gasoline. Perhaps with a dash of nitromethane, it will mix.
Franchi
I have read that zinc has been removed from motor oils to add to the bottom line. A great anti wear ingredient that may still only be found in oils for Diesel engines. I would use it but I can only find it in 20-50 weight.
Franchi
