Lawn Boy 2 cycle Ashless oil
No data I guess...
I'll stick with what the engineers figured out what would be best....and not with what "feels suitable".
The TC-W3 oil you use is fine and any JASO-FC or FD is very clean oil too , all suitable for a LB engine .
I would how-ever caution the use of castor bean oils such as Klotz or mix ratios of 100:1 even if the product says you are able to , you may certainly have issues running those in a LB or most any OPE .
That's all I have to say , do your own research .
I'll stick with what the engineers figured out what would be best....and not with what "feels suitable".[/QUOTE said:
Where is the fun with that?
Been running my yard sale find D series 16:1 on 32:1 for the last year and its happy.
My first post is in the oil wars thread! Wooohoo!
What oil are you using Canoester ?
Yes , you are a brave sole commenting in an oil thread on your 1st post :laughing:
To protect my 2 dollar investment I've used the following.
Supertech 2 cycle (current) 32:1 ( No smoke)
LawnBoy 2 cycle when I get to the local hdwe store 32:1 (They all seem to smoke with the real LB oil)
Pro Mix synthetic (universal blend for all ratios) for a couple tanks at 50:1
This is the third LB in the fleet and honestly I did not know it was supposed to be 16:1 till I carefully read the label on the mower.
Would you guys use Stihl motomix 2 stroke fuel readily mixed on a vintage Lawnboy mower?
No. Lawn-Boy spec calls for TC-W3 which is an ashless oil. Available everywhere.
Chainsaws run at much higher temperatures than Lawn-boy mowers.
