leafmulcher
- Oct 23, 2019
- 7
Hello,
12 year old Craftsman YTS4000 (917.289283) with about 1100 hours on it. Replaced the front wheel bushings with a sealed bearing kit and apparently "shimmed" the wheels too tight with the large washers (maybe 1/16" to 1/8" lateral movement). After approximately 10 hours of use, the weld on one of the wheel hubs broke apparently due to excessive side loading? Ordered two new wheel/tire combos with sealed bearings already installed from a company called "Antego".
Before replacing the original bushings with the bearings, there was a lot of lateral "slop" on the front wheels (guessing 1/2" to 3/4").
So, my question is, how much lateral movement of the wheel on the axle should there be when I install the new wheel/bearing combo?
Thanks in advance,
Mike
Thanks in advance,
Mike
