I’m taking some time this winter to repair the oil sump leak on my mean-green-grass-cuttin-machine as well as repair or maybe improve some other things while I’m at it. I thought it’d be nice to have a dedicated thread to share pics and ask advice as needed along the way.
Here’s the beast in all its original radiance and glory - sans deck, of course. Since I have limited garage space, the deck was better off stored in the shed and out of the way.
The primary goals are:
1) Oil sump leak - resealing entire engine while I’m at it.
2) Steering & linkage - gears are nearly stripped and the right tie rod is loose.
3) Front axle spindles - Replacing with all new components if possible. I need to verify it, but a quick glance while replacing the bushings this past spring made it look as though the right spindle was bent.
If time allows, I’d also like to:
(Edit) -Add temp gauge just because I like being able to monitor it.
-Make a custom set of less-than-impressive hub caps.
-Figure out how to reinforce or further stabilize the wheel bearings.
-Thoroughly clean tractor and touch up paint.
-Repair tear in seat.
-Service transmission.
-Repair/replace miscellaneous wiring that has cracked insulation.
I’ll update once or twice a week depending on progress. I’m only putting a few hours a week into this as there’s always more irons in the fire than this blacksmith can keep up with.
