I ordered a new pulley for the top of the trany.The splines look good,but there is some wear on the v of the pulley.I talked to the service dept. at the local JD dealer,and they think it's probably the bearings on the trany shaft.I admit,I did not remove those pieces and inspect them when tearing down the tranny.If the pulley isn't the culprit,I'll order the bearing kit.I'm convinced the rest of the tranny is fine.I'll let you know what I find out.As for checking the air gap on the PTO,I don't see anyplace on it to check the air gap.It's a Warner clutch,but I couldn't find the slots to check it.Maybe these are proprietary to JD?
