Hey guys .. Im kinda new so needed some help. I bought a John Deere la140 from a guy I knew it was a used mower but in great shape. low hours.. It needed a battery .. So i replaced the battery and engine would not Start..so replaced solenoid and engine fired right up smoothly.. Problem solved.. Well not so fast.. lol lol ... The blades would not engage so i checked power to the clutch and had good power clutch seemed a little old so i replaced the clutch. STILL no engagement. I noticed that the PTO switch plug had been cut off and spade connectors put on in place of.. So i replaced the PTO switch.. Still no help. But for some reason the engine will not turn over now. I broke the key trying to get it to start. So i replaced the Key switch also. STILL engine will not turn over. Replaced seat switch .. NO help.. replaced fuse.. No help.. I am looking for a wiring skematic to make sure the PTO switch is properly installed. But cant find the Schematic. Can anyone help me with this.? Or do you have any ideas on why my new PTO clutch will not engage ? ... Thanks
